969 views ·
What render or other can I use on the brick/existing render?
I have removed a door and was thinking of putting trim around it, but now I feel that I would prefer to apply render/similar and paint, as we have in another opening. The wallpaper on the adjoining walls will be replaced. The question is, what render should I use? Is there a ready-mixed product similar to filler that I can use, or do I need to buy something that needs mixing? It would be nice to avoid that if possible...
Exactly, gypsum plaster is very easy to mix, but you can also buy pre-mixed "husfix" at the hardware store.F Fjonken said:
Make sure not to apply it too thickly as gypsum plaster or "husfix" cannot be sanded (or is very hard) so it's better to apply another layer, or alternatively use regular hand putty to make it smooth and nice.
The advantage of gypsum plaster is that it can be sanded and is very easy to handle and maintain tools.anders07 said:
Exactly, gypsum plaster is very easy to mix, but you can also buy ready-mixed husfix at the building store.
Make sure not to apply too thickly as gypsum plaster or husfix cannot be sanded (or is very hard) so it's better to apply an additional layer, alternatively use regular hand putty to make it smooth and nice.
I've never used husfix but I guess it's a mix between something like 4040 and "regular" mortar? And that's not sandable, right? It's probably expensive too?
Plaster is also very hard and difficult to sand, but better than husfix.F Fjonken said:
Yes, husfix is more expensive, but it's only like a hundred or two extra for that surface, so the price difference isn't that big.
Gypsum plaster is sanded with 40 grit paperanders07 said:
Thanks for the quick responses. It ended up being husfix anyway. I probably mixed it with a little too little water so it became a bit hard to work with. I'm going to take the other side now and test with more water, so maybe it will be easier. But how do I do it in the upper part? Will it attach well there, or do I need to "reinforce" it in some way?
Work with layer upon layer, moisten the brick beforehand so it grips better.N Nitrex said:Thanks for the quick responses. I ended up using house fix anyway. I probably mixed it with too little water, so it was a bit hard to work with. I'm going to do the other side now and try with more water, so it might be easier. But how do I do the top part? Will it hold enough there, or do I need to "reinforce" it in some way?
Click here to reply
