In a bathroom, it is usually a bad idea. You will most likely need a new waterproofing layer, and then the old one has to be removed, you should never have two waterproofing layers enclosing moisture in between. But sure, if you consider a fairly recently done bathroom where you know everything is as it should be, but you don't like the look of the tiles... Then you can tile over.
