Hi!
I'm considering taking the easy route and laying new tiles on the existing tiles in the laundry room in the basement. Since it's a basement, it's important that the slab can "breathe" through the grout lines. If I lay new tiles, will it breathe through the grout lines of the bottom layer and then through the grout and out through the grout lines of the top layer, or do I risk sealing it too much?
It might be a bit convoluted, but I hope you understand what I mean.
How much ground moisture I have, I don't know, I don't have anything that directly indicates it would be particularly moist, but after all, it's an uninsulated slab. Do you know what problems might arise if I still lay tiles on tiles? I think that any moisture should still find its way up but perhaps I'm thinking wrong?BirgitS said:
But what can go wrong if the floor doesn't breathe enough, what will happen? I have plastered walls so the moisture should seek there, or can I expect another phenomenon?Forlowt said:
Bubbling paint on the walls, I would imagine.E Ebbe Eriksson said:
I've got the impression that it's best to let the floor breathe as much as possible. Then it all depends on how much moisture movement you have. All houses are unique.
Okay, thank you so much for the answers!
Click here to reply
