We have a company that builds loose lumber for us. Unfortunately, they started a bit too late or winter came a bit too early. Of course, according to them, there are no problems with moisture... but we feel it doesn't seem quite right. Have been shoveling snow all day and soon the slab will be visible again. Feels like the risk of moisture/mold problems has multiplied. What do you think about how this will develop in the future? Is it possible to get it dry, are there major risks, what should we watch out for, etc., etc., etc.
Feels like we need expert advice now :-X
Thanks in advance.
  • Wooden house frame under construction in a snowy landscape, surrounded by trees, highlighting concerns about moisture and potential mold growth.
As long as it is below zero degrees, the snow is dry. Make sure not to build that in.
As mentioned. The snow is dry so it is not a moisture problem. Just make sure to shovel and sweep it away before it melts and there won't be any issues. "Our" carpenters chose to build the roof during the winter specifically to avoid moisture problems.
That's not very good.
What is recommended for curtain walls, and should be applicable here as well (after Skanska's? fiasco in Hammarby Sjöstad) is the following (approximately);
* Use the "right" quality of timber.
* Only install the exterior gypsum on the wooden studs.
* Do not install insulation until the roof is sealed.
* Before installing insulation, check the moisture content.
There is a moisture-proofing scheme developed, which I believe can be obtained without it being Skanska, as it should be part of some development of the industry standard.
In your case, this means building from the outside in once the frame is erected, and not insulating until the moisture levels are down to what is acceptable.
Mikael_L
poiu said:
In your case, it means building from the outside in once the frame is erected, and not insulating until the moisture levels are down to what is acceptable.
But that's what you do anyway, even if it hasn't snowed and rained during the setup... ::)
Click here to reply
