12,497 views ·
12k views
Stone crib for dock, opinions on drawing?
Will it withstand the ice? Most cribs I've seen are made of pine logs and even they can break if the ice is severe. There is probably some useful information here on the forum as well if you look at piers.
The bridge is naturally situated facing south in a small bay, and the waterline will go about 30 cm below the top of the bridge. Which joints do you mean?A atomlab said:
Yep, but I've also seen much weaker cribs than my design that seem to hold up for decades...HasseTeknik said:
Where can you find a 2-meter stainless steel threaded rod?
Here is a place, there are more
https://www.a2a4.se/ovrig-infastnin...pMlygxlDsM9KMCcldg-phvNwTDFYWkwkaAqK7EALw_wcB
Then, having such weak timber and placing it on the outside of the posts is not good, any ice will break them off as it expands in the stone basket with outward pressure. No, it's only large timber that works if you want to keep the dock for several years.
Hello
I'm considering building something similar in a lake. Did you build it according to the sketch and has it withstood the ice?
Click here to reply
