Intend to build a deck according to the attached image. The width of the house is 7 m and I'm thinking of a deck depth of 4 m (or will that be too small?). So a deck of 7x4 m. The highest point will be nearly 3 m above the ground.
Illustration of a house with a proposed balcony design, featuring dimensions of 7x4 meters and supported by posts, illustrating construction plans.
I'm thinking of using 95x95 posts in post shoes drilled and cast into the bedrock. The posts will be continuous and form the railing posts.
I would preferably like to avoid placing a "middle" support beam with extra posts in the middle of the construction. Therefore, I'm wondering how I should dimension the build? What dimension is required for the "frame" beams? 170/195/220? Should the joist beams have the same dimension? What should be the spacing of the joist beams? How much distance can I afford between the posts - is 2 m too much with this construction? Other dimensioning questions to consider?
Thanks in advance.
2 meters spacing between the posts and 45 x220 in both the frame and joists (s600) is probably suitable.
45 x195 is a bit flexible over 4m
Use 28 thick decking to make it feel sturdier.
  • Like
Björkman
Use 145x34 trall, nicer and more stable.
  • Like
Björkman
Click here to reply
