8,614 views ·
9k views
Size of brackets for 40cm deep shelf
Hello,
We are going to install a new shelf in the kitchen that will be 40cm deep and 68cm wide. What size bracket should we aim for? Nice brackets in oak (like the shelf) seem to only go up to about 25cm, which feels a bit small.
What we plan to have on the shelf will weigh about 10kg, but we have two cats that will probably decide to jump up there, so we should probably account for significantly more.
For example, Clas Ohlson has longer brackets in oak, https://www.clasohlson.com/se/Hyllkonsol ek/Pr313958001
It is the limitations in load and demand that govern the supply. For heavier loads, metal constructions that can handle more weight are chosen.
Clas Ohlson had one in pine that is 340x415. Maybe it can be stained to oak?
It is possible.GoForIt said:
I found these now, and one could use the long side under the shelf and then the short along the wall, but the question is how to screw the short one since it only seems to have one screw hole?
https://www.bauhaus.se/carl-konsol-250x350mm-ek.html
A new hole is being drilled...
Unfortunately, the console is probably not designed for "reverse" mounting, so there is a risk that it might break under load. It also requires a good opportunity for fastening to the wall.
Click here to reply
