I have a straight staircase that I am planning to replace the treads and risers. New steps are insanely expensive. I'm thinking of making the treads out of 21 mm plywood, which I will then cover with some laminate flooring. Has anyone done this?
My father did it in a curved staircase 25 years ago, but with thin parquet + oak trim at the front. It works and still looks good, although you can feel the transition from parquet to trim.F Floskar said:
Diversearbetare
· Göteborg
· 11 306 posts
Why don't you cover the existing steps with the same laminate flooring? 21 mm plywood is very thin for steps. I don't think you can find thinner than 30 mm to buy, and that's stiff woods like oak. Stair materials in pine are always 40 mm.F Floskar said:
The staircase is from '69, creaks like hell, and I've tried to fix this, but it gets better for a while. There's also carpet on it, and the treads are 240 mm deep; I'd like to go up to 280-300. Thanks for the tip regarding stair materials. I've Googled like crazy and am in the industry. 30 mm plywood is also available.Johan Gunverth said:
Diversearbetare
· Göteborg
· 11 306 posts
Then I'm on board. Sounds like a good idea to replace it then. Plywood may be strong, but it is not rigid. It could probably be a bit scary to walk on those stairs if the steps give way.
Ah, I thought you were going to reinforce the steps with 22 mm plywood.F Floskar said:The staircase is from 69, creaks like hell and I've tried to fix it but it gets better for a while. There's also carpet on it and the steps are 240 mm deep, I'd like to go up to 280-300. Thanks for the tip regarding staircase materials. I've googled like crazy and am in the industry. 30 mm plywood is also available.
Click here to reply
