D Danii KD #1 Member · Stockholm · 515 posts 17 Jun 2021 at 11:21 AM Danii KD Member Stockholm 515 posts 17 Jun 2021 at 11:21 AM #1 Hello! If you need to grind away weld seams, which option is best? Grinding wheel or flap disc? Is there a difference between flap disc and lamellrondell? Thanks in advance! #grinding-weld-seam
D Daniel 109 #2 Member · E · 39 679 posts 17 Jun 2021 at 11:25 AM Daniel 109 Member E 39,679 posts 17 Jun 2021 at 11:25 AM #2 It depends on the purpose. If you want a nice surface, flap discs are good. If you want to remove material, the regular grinding disc is more effective.
