19,455 views ·
19k views
Molly plug won't attach to drywall
That should be enough through a 45mm stud, provided it is a wall with just one layer of drywall. However, 74mm sounds like a lot for a simple drywall anchor, they are usually only 45-60mm depending on the dimension.M Förstagångsköparen said:
Ok, one last test. Screw in the screw so that it just catches in the anchor and measure the protrusion, how far outside the wall does the screw head end up?
Hello.M Förstagångsköparen said:
You're not using the same screw as with Molly for these, are you?
For these, you should use a regular wood screw and not a machine screw. If the stud is 45mm, and the drywall is 13, then a screw with a length of 75-80 should be quite suitable, giving you a 2cm margin.
So a screw 5x85
If you’re close to Hornbach, you can buy them in bulk,
otherwise you have
https://www.biltema.se/bygg/fastelement/traskruvar/traskruv-kullrig-50-x-80-mm-2000047358
https://www.biltema.se/bygg/fastelement/traskruvar/traskruv-elforzinkad-fzb-2000046255
I had wood screws. 5x85K Kanelbullen123 said:Hello.
You don't use the same screw as for Molly with these, right?
For these, you should use a regular wood screw and not a machine screw. If the rule is 45mm, and the plaster 13, then a screw with a length of 75-80 should be quite suitable, giving you a 2cm margin.
So a screw 5x85
if you're close to Hornbach, they have them in bulk,
otherwise, you have
[link]
[link]
I never mount Molly without pliers. https://www.biltema.se/verktyg/handverktyg/tanger/specialtanger/metallexpandertang-2000047092
By only screw-expanding it, I find it too often easy to either tighten too little so that it doesn't secure properly, or too much so that threads on the screw or nut break.
Other mistakes I've made include using a Molly plug for double drywall on single drywall. That also went to hell, but I don't remember exactly how it manifested. The brand I buy is marked 4E & 5E for single drywall, and 4D/5D for double drywall.
In the video, it looks a bit odd. If the plug is fully expanded on the backside, it shouldn't flex back and forth unless it's been over-tightened. It should be rigid. So try tightening a bit more, or try with a new plug?
It should turn out something like this.
Click here to reply
