19,423 views ·
19k views
Molly plug won't attach to drywall
Have you expanded the molly with a molly tool? Is it the right molly for the board thickness? What do you mean by "drilled out the screw"?M Förstagångsköparen said:
Smart alek
· östergötland
· 2 825 posts
You need to make it expand at the back.
Easiest with pliers for the purpose..
It can be done by screwing in the screw, but it usually results in it spinning and messing up the wall.
You don't seem to have expanded the back of the plug yet.
How to do it:
Why you do it:
https://bygg.se/mollyplugg/
How to do it:
Why you do it:
Or you can choose a thinner stud or countersink the screw into the stud.M Förstagångsköparen said:
What are you attaching that makes you choose such a thick stud?
I've placed all the other screws in the studs (they were easy to see). But at the very end of the wall on one side, there is no stud, so I need to use a molly plug.D Dilato said:
