Member
· östergötland
· 8 posts
Hello!
I have cut an MDF board that is 2400 * 920 (19mm thick) that I have placed on 2 trestles from IKEA.
I now need to make the whole construction more stable. I have mounted a support rail against the wall, but it still flexes.
I have considered using wall brackets instead of trestles, but can't find any that are deep enough.
Ps. I have 0 experience with building with MDF and no experience at all when it comes to building furniture.
Member
· östergötland
· 8 posts
mmm thought so, but then I'll have it in my lap when I'm sitting here.
I could, however, raise the table a bit. today it's 72 up to the edge of the table.
Grundstött
· Halland
· 28 345 posts
72 centimeters is just the right height for a desk or dining table.
It's probably actually "standard."
But surely you have room for a reinforcing "regel" along the table edge?
I can recommend glespanel 28x70 mm, stood on edge of course.
However, if you think it provides too little room for your knees, you can choose a 45x45 mm regel instead.
Member
· Blekinge
· 12 449 posts
You can move the bockarna slightly inward.
You can screw an ELFA wall rail (they have a U-profile) onto the front and back.
Member
· östergötland
· 8 posts
What do you think, will this be good do you think?
Grundstött
· Halland
· 28 345 posts
Member
· Västernorrland
· 12 080 posts
Why not put the ruler in the wall on the table top instead? It can sit inside the holes.
Click here to reply
