Wind barrier works excellently when placed against the roof; in old houses, the paper was used and it has worked well, so there shouldn't be any problems at all. Otherwise, you can just use cover paper if you want, as the function, as I understand it, is just to keep the sawdust in place so it doesn't fall down.
