Hello.
What is recommended here? I've done some work so this wall with plasterboard got a bit worn. How do I fill the gap? Fill with putty in stages or? There are also screw holes in the plasterboard to a void in the wall. I want to restore the evenness without tearing down the whole wall and installing new boards.
Damaged drywall with gaps and screw holes on a wall, showing wear and tear. Rough edges and exposed screws indicate need for repair and smoothing. Damaged wall with two large holes, one revealing a cavity, and a visible screw in drywall.
Fill with plaster, it doesn't sink. Putty for joints and screw heads. Bevel the edges of the drywall.
Then you need to place tape over the joints.
  • Like
Mattias_Jo1 and 1 other
AXS
That should be enough with only coarse filler on that?
Gypsum plaster is great, but it sucks to buy a whole can and only use 1dl.
Maybe Husfix or some type of adhesive if you have it at home.
  • Like
Mattias_Jo1
Yes, coarse filler can probably suffice. "One strike filler" is a pre-mixed filling compound that also doesn't shrink.
  • Like
Click here to reply
