L läppglans #1 Member · Stockholm · 100 posts 25 Feb 2010 at 8:42 PM läppglans Member Stockholm 100 posts 25 Feb 2010 at 8:42 PM #1 hi, I'm building a drywall frame for a gypsum wall. I was wondering if anyone knows if it's okay to screw the holders into the wooden floor (3cm thick) or if I should take up the floor and screw into the concrete instead???
L lajsiiwan #2 Member · Skåne · 133 posts 25 Feb 2010 at 9:33 PM lajsiiwan Member Skåne 133 posts 25 Feb 2010 at 9:33 PM #2 As I see it, it basically doesn't matter.
L läppglans #3 Member · Stockholm · 100 posts 25 Feb 2010 at 10:11 PM läppglans Member Stockholm 100 posts 25 Feb 2010 at 10:11 PM #3 I'm asking because I got the idea that the floor is moving and then the wall will crack if I screw it to the floor?
L lajsiiwan #4 Member · Skåne · 133 posts 26 Feb 2010 at 5:52 PM lajsiiwan Member Skåne 133 posts 26 Feb 2010 at 5:52 PM #4 Cut a groove and adjust the rule if you're worried
R Richtmann #5 Member · Västerbotten · 21 posts 26 Feb 2010 at 7:25 PM Richtmann Member Västerbotten 21 posts 26 Feb 2010 at 7:25 PM #5 There is no problem with screwing into the floor, there will be no problems at all.
