Hobby electrician
· E
· 15 595 posts
A cut nail is surely cut to have a harder time crawling out?
/Not a carpenter, former electrician...
A thousand thanks!
I don't know if I dare drive a 40mm nail into a window frame from the top. Maybe it's an unfounded fear!?
I need to attach a 21mm molding on the top. It's a strange construction from when the house was built.
Feedback:
I used a 50mm cut dyckert at the top edge of the Elitfönster vision. The strip that was attached with the dyckert was 21mm planed. It turned out perfect.
Used 4 nails and the window is 120cm wide.
Click here to reply
