I hope someone here can offer some smart tips and advice about our balcony. The balcony is a steel structure with decking where the joists are screwed into the steel construction.
Under the decking, plastic has been laid, and under the plastic/surface layer on the underside of the balcony is some form of plywood with a slight slope away from the house.
The plywood has now become seriously water-damaged, swollen, and delaminated.
The first thing to do is pretty simple, remove the plywood and plastic. But what should I do next,
Leave it open under the decking so rainwater comes down onto the terrace below?
Install some form of metal roofing on the underside of the balcony? Is there a risk that the joists will rot since they may have difficulty drying after rain and snow?
Another solution?
  • Underside of a balcony showing severely water-damaged, swollen, and delaminated plywood, with a garden and windows visible in the background.
Click here to reply
