I have a few bottles of construction adhesive (mainly PL400) that are unopened and are approaching their EXP date soon, and I was wondering if you have any experience with freezing them to thaw and use the adhesive later? Would that work?
frost and glue are something that never go hand in hand glue and foam are perishable goods that should be used
even if it has exp it lasts a while when it gets hard in the tube you should throw it away
although if it has expired, it will last a while when it hardens in the tube, you should throw it
Tec7, for example, can, according to the manufacturer, be frozen and thawed several times without losing its properties, so it absolutely does. Whether it extends the expiration date, I'll leave unsaid.
Click here to reply
