I am going to build a low retaining wall and plan to lay granite stone slabs on top. But what should be used for jointing material? I have heard that mortar might not adhere well to granite?
Stone adhesive seems like the obvious choice, but it's a bit scary/messy around finished surfaces. (It's somewhat like expanding foam)
Thanks, @Rickard. However, not much of the joint will be visible since the soil masses will go up a few cm on the edge of the granite curb. Is the stone adhesive more durable than the assembly adhesive in this case?
