1,457 views ·
1k views
Anyone know what this material is
Is it hard as stone worried that it is eternit?
https://femtiotalsjakten.blogg.se/2009/june/golvet.html Looks like it is something similar
Yep, it was vinyl flooring at the time and not linoleum flooring as I wrote. They came in a variety of colors and were square, rock-hard, fully glued. Cutting them was like cutting window glass, a score and a snap against an edge. It was plastic all the way through and no threads or net embedded, how is it yoursO Olof Olofsson1 said:
They were completely glued, haven't taken anything apart so don't know if there was anything inside.
The small piece in the picture is a divided tile.J jonaserik said:Yep, it was vinyl flooring at that time and not linoleum flooring as I wrote. They came in a lot of different colors and were square, rock-hard, and fully glued. Breaking them was like breaking a windowpane, a score and a snap against an edge. It was plastic all the way through and no threads or mesh embedded, how are yours?
And just pried off, then it becomes twisted at the break. Maybe it was a bit easy to snap off a piece, just breaks off during removal. Don't believe there's any asbestos in those tiles. What are you going to do, tear everything out, it looks like there's a tongued and grooved masonite floor underneath and then if you pry everything off, the masonite will split apart and masonite pieces will follow along, attached to the tiles.
I'm planning to remove the Masonite as there are a lot of adhesive residues on it. Then lay a new floor. There's raw plank flooring underneath.
Click here to reply
