Vermilion #1 Homeowner · Västernorrland · 643 posts 3 Mar 2020 at 2:21 PM Vermilion Homeowner Västernorrland 643 posts 3 Mar 2020 at 2:21 PM #1 I attached tiles with light adhesive to a primed wooden batten but it sticks poorly and can be easily removed with a putty knife. Is there any cheap tube adhesive I can use instead so the tiles stay? #tiles #adhesive
Stefan N #2 Tool enthusiast · Stockholm Täby · 13 696 posts 3 Mar 2020 at 3:25 PM Stefan N Tool enthusiast Stockholm Täby 13,696 posts 3 Mar 2020 at 3:25 PM #2 You need something like construction adhesive such as PL400 or similar; you can't use fix on wood.
Vermilion #3 Homeowner · Västernorrland · 643 posts 5 Mar 2020 at 10:17 PM Vermilion Homeowner Västernorrland 643 posts 5 Mar 2020 at 10:17 PM #3 Stefan N said: You need some type of adhesive like PL400 or similar, it won't work with fix on wood. No, I learned the hard way about that Since a lot of adhesive will be needed, can you buy it as a powder to mix or are cartridges the only option?
Stefan N #4 Tool enthusiast · Stockholm Täby · 13 696 posts 6 Mar 2020 at 8:01 AM Stefan N Tool enthusiast Stockholm Täby 13,696 posts 6 Mar 2020 at 8:01 AM #4 Where do you have this träregel?
Vermilion #5 Homeowner · Västernorrland · 643 posts 6 Mar 2020 at 11:12 AM Vermilion Homeowner Västernorrland 643 posts 6 Mar 2020 at 11:12 AM #5 Stefan N said: Where do you have this wooden rule? at the very bottom against the floor in a garage.
