6,798 views ·
7k views
What happens to polystyrene directly in the soil over time?
As the title says, what happens to foam plastic that is directly in the soil over time? I've built a retaining wall that needs to be backfilled but underestimated how much soil was needed.
If the foam plastic retains its shape despite constant moisture/water/frost, maybe I can fill it with some EPS I have lying around?
Best answer
Dug on my property between the garage and the house to lay a cable, and there's polystyrene in the ground along the slab, not sure why. But anyway, nothing had happened to the polystyrene that was placed in the ground 28 years ago.
Sounds positive! And was it lying directly in the soil without any draining material?Isakare said:
It's probably the edge insulation you've found. Styrofoam is placed like that so that the frost doesn't find its way under the slab.Isakare said:
Gravel type 10 cm closest to the slab, but the boards extended 60 out, and the rest was just in soil. The boards are laid tilted outward, about 45 degrees, so at the farthest point there was probably 50 cm of soil over.J JockeHX said:
Great. Now I feel like I can fill in with some foam plastic with a clear conscienceIsakare said:
A stretch of road was constructed here where I live, it's a fairly steep hill where heavy trucks transport stone from the Stockholm bypass. The entire embankment was built with polystyrene, and we're talking layers of several meters, which were then filled with macadam and paved.J JockeHX said:
Click here to reply
