3,402 views ·
3k views
Door trim with poor prospects from the start
Yes, the door is on the wrong side of the door frame....
Then you need a "smyg", you can buy pre-painted ones, or alternatively use a trim (like 21x33 in your case). They often need to be cut to length to fit, and you can also compensate if it's crooked (the frame should always be plumb, the wall can tilt).
Best answer
Yeah, it works, but it does hurt the eyes a bit for those of us who know how it should have been doneJ Johan41 said:
Click here to reply
