1,577 views ·
2k views
Intermediate joist 45x220 has shrunk
We built a 1.5-story house in January 2019, which was completely finished in June. I am now decorating the upper floor and have a small concern in connection with this. Since we are going to have a bathroom on the upper floor, I need to add new 45x220 C24 joists so I can achieve CC30 exactly where the bathroom will be. The problem is that the new 45x220 joists I have installed are higher than the existing ones that have been in place for almost a year. The existing ones are up to 10 mm lower (about 210 mm).
This poses a problem when I am going to lay chipboard on this; how should one best solve this? Should I plane down the new ones so they are at the same level, or what should be done? It's worth mentioning that it's the exact same timber (SCA 45x220 C24 G4-2).
That thought crossed my mind too... However, it feels tedious to wait for drying when we've already started the project. Ordered stairs, plumber, etc. How long might one need to wait, do you think? I want to be able to lay down the floorboards so we can put up a ladder and insulate up to the ridge. Might need to buy a moisture meter...useless said:
Thanks for your response. I am currently leaning towards planing some down. I've noticed that it's not just the newly inserted beams that are higher; the rafters also differ from other intermediate beams. Otherwise, I will have a nightmare with the floor installation.S sixten88 said:
Click here to reply
Similar threads
Ljudisolering & ångspärr under parkett på mellanbjälklag i lättbetong?
Golv -
Do I need double studs 2x45x220 for intermediate flooring?
Building Materials and Construction Technology -
Steel beam HEB180 in intermediate floor align top or bottom with 45x220
