Hi, if I want to find out if the wall is load-bearing or not, who should I ask? How much can it cost? I live north of Stockholm.
Kan själv!
· Trelleborg
· 20 411 posts
That wall is almost certainly load-bearing.
Kan själv!
· Trelleborg
· 20 411 posts
1.5 stories for the first, with quite a large span, I think it's difficult with self-supporting trusses for that.
Then you have a wall that goes across the entire house along the middle. The separating partition at the dining area would also be load-bearing in that case.
Although it looks quite thin. How thick is it, and is it the same thickness on all other walls?
Is there a beam above the opening between the hall and the living room?
When was the house built?
It might be a good idea to contact the municipality and see if they have more drawings and building descriptions.
Member
· Blekinge
· 10 117 posts
The wall is definitely load-bearing. The openings are supported with beams. This is shown by the dashed-dotted lines.
Best answer
Member
· Blekinge
· 10 117 posts
No, it is not that wall. However, the section drawing shows that the hjärtväggen, the longitudinal wall in the middle of the house, is load-bearing. The bottom plate has a reinforcement approximately in the middle to be able to take on larger loads.
Click here to reply
