1 737 läst ·
11 svar
11 svar
Garage radiator
Hi all,
I am seeking advice on heating for the garage.
It has to be run on electric as there is not heat source form the pump in the main house.
Should i go for straight up electric heaters or are oil based electric heaters better - i'm looking for efficiency more than anything.
Any recommendations?
Thanks
H
PS Sorry again for the English.
Thanks
H
I hadnt considered something like this, would that be appropriate for keeping a garage warm - this is just for the purposes of winter time, I'm not going to be doing much work in there probably maintain 12 degrees during the winter months.
I was looking at something like this - https://www.jula.se/catalog/bygg-oc...da-element/oljefylld-elradiator-430121/#tab02
But then found electric elements, its a real struggle relying on translate sometimes
Perhaps I can explain better. The garage is two separate spaces, each approx 20m2, the intention is to have each stay "warm" during the winter, perhaps 10-12 degrees.
I guess i need to look at the manuals of the options and see what the KW/H cost is.
Thanks for helping - im aready 10 steps forward form when I started.
An ordinary electric heater is a cheap way of getting some heat, note that you get the same amount of heat irrespectively of heater type, ie an oil filled heater doesn't give you more heat compared with one without oil.
The only way of getting more heat/kWh is to use a heat pump.
I've been reading about heat pumps, some comments on the struggle maintaining low temperature 10-15 degrees in winter without freezing.
I guess the advantage to oil is they get hot quicker perhaps and take longer to cool - better thermal efficiency perhaps.
Thank you for your time @etompau you have been very helpful.
Another thing that's important is where (in Sweden?) you live.
In the very south, it will take a long time to make up for the investment from a heat pump.
In the very north it will be fast.
/ Best regards, Fredrik
im about 3 hour north of Stockholm, in Dalarna,
This is a new built garage so the retrun on investment is not a major concern, but the fine balance between economy and maintenance costs, Oil heaters buy use and then discard when they stop functioning. Theres regular maintenance of heat pumps.
Im open to both ideas as a principle, just want to hopefully make the best fit.
