Hello,
I am planning to build a greenhouse with some old windows I have. I planned to have a beam 95x95 on posts, against which I would then mount the windows directly. I have managed to get hold of quite large old glass units with double glass at 1400x2000, so they are quite massive.
Is it fine to use a 95x95 beam, or is the risk of them warping and cracking the glass higher than if I use two 45x90 beams and tie them together? The posts are spaced just over 1.5m apart, so they should help prevent them from twisting too much, I think. What do you all think?
Diversearbetare
· Göteborg
· 11 226 posts
Can't you use glulam instead?
Member
· Blekinge
· 10 117 posts
Two screw-glued 45x95 on edge will be somewhat stiffer than a 95x95, but with the short span of 1.5 meters, both options work. Use strength-graded timber, preferably C 24.
Diversearbetare
· Göteborg
· 11 226 posts
Most lumber dealers can order from Martinssons. They have 90x90 pressure-treated glulam, GL28-rated. I have personally made porch fence posts with their pressure-treated 115x115 and painted them.
https://www.martinsons.se/byggprodukter/limtrabalk-pelare/sortiment
Did you wait before painting the impregnated laminated posts, or did you paint immediately without letting them dry? How has it held up? What type of paint did you use?Johan Gunverth said:
Diversearbetare
· Göteborg
· 11 226 posts
They were quite nice and dry when I bought them, so maybe 2-3 months later they were painted. Industrial primer/Bettgrund first and then Flügger Primolin oil-based naftalöst paint. At my dad's place, it has held up for over 20 years without any issues.
The mentioned glulam beams are available at Bauhaus by the way.
Click here to reply
