383 views ·
Which glue should I use for drywall?
I am going to put up drywall on an existing wall. Two walls are concrete and one is light concrete. The walls are a bit uneven, so I was thinking of gluing the drywall before I screw (?) them in place. There are a total of seven drywall sheets. What type of glue should be used? I was advised to use some form of construction adhesive, I think, but I am quite unsure, it's quite a jungle.
If the irregularities you have on existing walls consist of valleys, not peaks, then your idea to glue up drywall might work. Any "goo" in a tube should work, buy the cheapest you can find at places like Biltema/Jula and apply generously....
But if it's only in a few spots, I don't understand why you don't just fill and sand instead.
It was a carpenter who recommended I do this. But there is quite a bit of sanding to do before you can fill.K Kasken said:If the unevenness on your existing walls consists of valleys, not peaks, then your idea of gluing up plasterboard might work. Any "adhesive" in a tube should do, buy the cheapest you can find at places like Biltema/Jula and apply liberally....
But if it's only in a few spots, I don't understand why you wouldn't just fill and sand instead.
Click here to reply
