14,577 views ·
15k views
What should I use as a subfloor panel?
There is special, impregnated plywood. It is usually called "blindbottenskiva" or "-board". It is laid on supports of planks that are nailed under the floor joists. We used thick asfaboard (19 mm against standard 12). It works well but is not penetration-proof, which is a requirement if craftsmen are involved.
Member
· Västra Götaland
· 219 posts
I have installed underfloor heating, water-borne. So I mounted a façade board, 50 mm thick mineral wool as a subfloor.
Then I put in battens as a support for the ceiling.
That way I get extra insulation against the basement and crawl space.
Click here to reply
