Saw that they had long finger-jointed beams at Byggmax https://www.byggmax.se/45x220-regel-fingerskarvad-c24-p662009
Suppose you need a beam on pillars longer than the longest beam they have. Is it better to splice the beam on a pillar yourself or to use a longer finger-jointed beam where the joints are between pillars?
  • Like
largab
M Martin Lj said:
I saw that they had long finger-jointed studs at Byggmax [link]
Suppose you need a beam on pillars that is longer than the longest stud they have. Is it then better to splice the stud yourself on a pillar or instead use a longer finger-jointed beam where the joints are between pillars?
It is certainly "better" to use a longer finger-jointed stud. It is classified as C24 and this applies to the entire stud including the finger joints. A well-executed finger joint is stronger than the wood around it.
P
You should not splice in the middle of a plinth or an opening regardless.
  • Like
Huzzbutt
Erik_Hansson said:
You should not splice in the middle of a blint or pitch regardless.
How should you splice if the rule is too short?
P
With a biscuit joiner. Around 1/3 of the distance between the spreads is suitable. I can't find my book with tables right now, but I found an image of a joint on Träguiden.
Of course, it can also be done with nail plates.
  • Like
Huzzbutt
Does the joint become as strong as without a joint using this method, or should one place the joint on a plinth combined with a splice board?
P
No, it will be stronger if the joint is not on the plinth.
  • Like
Huzzbutt
Interesting and spontaneously not entirely intuitive. Is there any reasoning behind that?
If you have tongue and groove on both sides and glue the joint properly, the seam will become stronger than the rest of the board.
  • Like
Alfredo and 1 other
T Tsdoesds said:
Interesting and not entirely intuitive at first glance. Is there any reasoning behind it?
The forces exerted through the cross-section of the beam are greatest at each support point and midway between each support point.
I think ;)
  • Like
Alfredo and 2 others
P
I think ;)
Correct. Then there is a breaking force / pulling apart. If you instead splice 1/3 in from the support, it becomes a shear that needs to be absorbed, which is also easier to counteract.
  • Diagram illustrating bending and shear in a beam with arrows showing forces applied at different points, supported by two columns.
  • Like
parvel and 5 others
V vectrex said:
The forces exerted through the cross-section of the beam are greatest at each support point and halfway between each support point.
I think ;)
I understand. One thought might otherwise be that there is support when the joint rests directly on a pier. But now I'm starting to feel like I may have misunderstood the main question.
Moreover, my feeling is that finger joints are weaker than completely knot-free timber. This is from an experiment to lift an old lamppost with a jack, blocking, and 2”5”. Finger-jointed timber gave way and snapped. Knotty timber as well. Then there was a piece of timber with tight growth rings, no knots, which was absolutely incredible. The post went up anyway!
T Tsdoesds said:
I understand. An alternative thought might be that there is support when the joint rests directly on the plinth. But now I'm starting to feel that I might have misunderstood the main question.
Moreover, my feeling is that finger joints are weaker than completely knot-free timber. This from an experiment to jack up an old lamppost with a jack, blocking, and 2”5”. Finger-jointed wood gave way and snapped. Knotty wood likewise. Then there was a piece of timber with tight growth rings, no knots, which was absolutely amazing. The post went up anyway!
That is absolutely true, but it’s not the finger joints that make it weak, it’s the knots. It’s difficult to find timber that is completely knot-free; you’ll have to search for a long time.
Erik_Hansson said:
Correct. It becomes a tensile force then. If you splice 1/3 in from the opening, it will instead be a shear force that needs to be absorbed, which is also easier to resist.
Well explained!
Best answer
The theory behind placing the joints on a beam about 1/3 from the supports is based on the idea that the joint should be made where the bending moment is zero. A beam that is supported on several supports (called continuous) has its largest positive bending moment midway between the supports and its largest negative bending moment (largest) over the supports. Somewhere in between, the bending moment changes direction and passes through zero.
When it comes to headers, i.e., the third supporting level after floor timber, and beams, other aspects need to be considered, especially shear forces. The timber's ability to handle these depends on the cross-sectional area, regardless of the strength class. Therefore, it is often a better strategy to use double joists, with lower height, with staggered joints for the headers. The properties of finger-jointed timber are best utilized as beams (second level) over multiple supports.
  • Like
Pielstick and 5 others
Click here to reply
