Hello hello.
As I said, I'm very curious if anyone has a good site with information on the span of different dimensions of lumber. Trying to explain a bit more simply.
Just thinking for example, if you build a small deck, I might choose to use joists 95 x 45. But then the question is... how far can it be between the "support, brace" under the joist before there's a risk of it bending? Is there any good information site where you can read about such things?
Thanks
Ola78
Rome said:
Hey hey.
As mentioned. I am very curious if someone has a good site with information about the span of different dimensions of timber. Trying to explain a bit simply.
Just thinking for example, if building a small deck, I might choose to use joists 95 x 45. but then the question is... how far can it be between the "support, the brace" under the joist before there is a risk of it bending? Is there a good information site where you can read about such things?
Thanks
Google the word span table and you will find information about what different joists can handle. At http://www.byggbeskrivningar.se you will find a design program where you can calculate various constructions and spans and find out which dimensions you can choose. Also at http://www.traguiden.se you will find various tables about what different dimensions can handle for spans.
Click here to reply
