Building a small shed for pool equipment, and based on the ceiling height, I would like to build the roof from 44x70, which is admittedly quite weak, but does anyone with expertise have an idea of approximately how well it would hold up?
The shed measures 2 meters in width and 1.3 meters in depth. The rafters would have a span of 1.3 meters and I can set them closely together. On top, tongue and groove boards are planned, with felt and metal sheeting.
8-degree pitch.
How bad an idea is this?
8 degrees is a low slope and 70mm is thin in the context of roof trusses. What snow zone do you live in?
I have never seen roof trusses under 45x120 and then with reinforcement (w or framework) if you are going to build a gable roof, but on the other hand, it's only a 2m span... But are you perhaps looking for a single beam over like a monopitch roof (truss in one section) rather than a gable roof?
In Snow Zone 1, it should, according to the guide, work with 45x120 C24. If you place it on the depth (1.3m) you might manage with 45x95 even...in the same way if you place them closer than cc 120
https://www.traguiden.se/konstrukti...uktionsvirke-i-ett-fack/?previousState=000100
klaskarlsson klaskarlsson said:
8 degrees is a low slope and 70mm is thin in the context of roof trusses. Which snow zone do you live in?
I have never seen roof trusses under 45x120 and then with reinforcement (w or framework) if you are going to build a gabled roof, but on the other hand, it's only a 2m span...
But are you perhaps looking for a single rafter over like a pent roof (truss in one section) rather than a gabled roof?
In Snow Zone 1, it should then, according to the guide, work with 45x120 C24. If you place it at depth (1.3m) you might manage with 45x95 even...in the same way, if you set them closer than cc 120
[link]
It really is roof trusses within “ ” … It's going to be a shed like this, so it's quite simple. Even 45x70 is actually too tall, but it's the lowest I'm considering going. I think it should hold up, but we'll see.
  • Wooden garden shed with slanted roof and double doors. Appears on a website named "Förråd Garden" with dimensions and detail drawings.
T Tokv41 said:
It really is roof trusses in " " … Will be a shed like this so it's quite simple. Even 45x70 is actually too high but the lowest I'm considering. I think it should hold but we'll see.
Yes, that's what I thought, it might not be a truss as much as a "beam that holds the roof" (called on träguiden "Roof beams in a compartment")
2m is not completely unproblematic for a 45x70 though, with an 8-degree slope and a meter of snow on it, it can become quite a bit of weight, I would probably go up to 45x95... but then again: If you set like cc 60, you might manage. And it's not a disaster if it breaks either, you can just rebuild it next summer :)
  • Like
mulle77
Yes, that's what I thought, maybe it's not so much a truss as a "beam that holds the roof" (called "Roof beams in a compartment" in the wood guide)
2m is not entirely unproblematic for a 45x70 though, with an 8-degree slope and a meter of snow it can be quite a bit of weight, I would probably go up to 45x95...but in any case: If you place them at about cc 60, you might manage. And it's not a disaster if it breaks, maybe, you can rebuild it next summer anyway :)
Exactly, and I can place them at cc 30 if needed too. And very, very rarely does it get a meter of snow in Uppland. And if it does, I can redo the roof as mentioned.
V
I have built similar with 45x95 with 100 cm spacing and it has endured several winters. We live in southern Dalarna.
  • Like
klaskarlsson
When you sit inside and start feeling "oh, there's a lot of heavy snow on the roof now," you go out and sweep some of it down... I see dimensioning of the roof for that type of building as a non-issue... :thinking:
  • Like
Styrman_jansson and 1 other
Run 70x70 and set them cc 600 and I would at least feel calm.
  • Like
Tokv41
Or buy glulam 56x225 and lay it on the slab c-c 600.
You get a thinner roof (which you want) and with a span of only 1.3m, I would sleep well even if a lot of snow came.
  • Like
Tokv41
"The fall on the roof is only 140 mm.
Buy 45x195 or 45x220 and cut away a wedge on both sides.
Making a classic W-rafter would be ridiculous.
protte
prototypen prototypen said:
"The slope on the roof is only 140 mm.
buy 45x195 or 45x220 and cut a wedge on both sides.
Making a classic W-truss would be ridiculous.
protte
45x220 feels rather overkill. Moreover, the ceiling height inside the small shed would be reduced significantly unfortunately. It will have to be 45x70 and we'll see how it holds. My guess is that it will make it, and if it doesn't, I'll redo it after the winter.
  • Like
Daniel Barnaniel
I Ingenjör Jesper said:
When you're sitting inside and start feeling "oh, there's a lot of heavy snow on the roof," you go out and sweep some of it off... I see the dimensioning of roofs for that type of building as a non-issue... :thinking:
That's how I think too. I have a "kit shed" from Bauhaus measuring 1.4x2.8m with a pent roof where the tongue and groove boards only rest on the outer walls and two 28x120 boards screwed together in the middle in the direction of the "long side."
Shoveled off the snow when it was about 30cm on the roof….
I usually over-dimension but now it's really the other way around.
This is how it looks. The reason I don't want to build with thicker dimensions is to get as much height as possible inside the small shed while not exceeding 120 cm in external dimensions. Partially, the "shed" is buried and will stand under the decking.
It will contain a sand filter and a pool pump.
I will use joists and reinforce, but right now I'm most concerned about the opening which is 80 cm wide. There, I see the greatest risk for sagging. Wooden shed frame under construction, partially covered with tarp, on a gravel surface. Interior shows initial setup with cables and some boards inside.
What do you think about the load-bearing capacity? We will remove snow regardless of the dimension of the timber, but is it obviously too weak for such a small shed?
T Tokv41 said:
What do you think about the load-bearing capacity? We will remove the snow regardless of the dimension of the timber, but is it obviously too weak for such a small shed?
I can't imagine there will be any problems.
/G
