The span table on the wood guide shows that 45x220mm floor joists can handle spans of up to 7m with a center support underneath.
I need to cover a span of 7.5 meters. It probably would have worked with 45x220mm, it just would have flexed a bit more.
I was at the sawmill today and asked, and unfortunately, he didn't have as many long 2"9 (45x220mm planed) as I needed, nor any higher dimensions. However, he had quite a lot of 3"8. How large spans can 3"8 handle?
Haha, got an email saying there were replies in the thread "Maybe 6 m., it is about 14% weaker." Thought "What?! I thought it would be stronger than 2"9!
But now it says it is stronger, which aligns more with my own feeling (which is completely unfounded
You seem to have a handle on this peternicklas. How did you calculate it is 14% stronger?
Click here to reply
Similar threads
Inreda dubbelgarage på 38 kvm, inspiration tack!
Övrigt husrelaterat -
Spännvidd på golvbjälkar.
Lösvirke & Timmerhus -
Altanbygge. Välja kortare spännvidd eller öka dimension på bär-/golvbjälkar
Altan & Uteplats -
Floor joists / floor beams span between pillars
Building Materials and Construction Technology -
Span of floor joists.
