D
What is the longest span on a ramp/gently sloping staircase?
I was thinking of using two parallel 45x220 C24 beams but am considering the longest span. The distance between the parallel beams will be somewhere around 100-120 cm. Snow zone 2.
I read different things in the available guides.
I don't understand the question? Are you referring to the vangern of a staircase?
Edit: I missed that it said ramp. Someone else will have to answer that. But spontaneously, I think you could aim for the calculations in the dimensioning table for heavy flooring. Somewhere in that region, I think it falls.
Click here to reply
