Hello!
I want to remove plaster with a rough (about 5 mm deep), striped texture from some (concrete) walls indoors, above ground. The plaster is painted over, but I assume it is gypsum plaster (how can you tell the difference?). What kind of tools would you recommend to remove/even out the entire layer of plaster to achieve a smooth and paintable surface?
Best regards,
The happy amateur
