Hello,
I would need help from someone with some knowledge about spans and deflection.
We hope to install a glulam beam 90X315mm with a span of approximately 5.5 meters. Supported on 90x90 posts at the ends. There is barely any load on this, only a number of cross-connected battens but no roof, for example, adding weight. Can we expect this to hold its shape without sagging under its own weight?
This is intended to be part of a larger outdoor pergola design.
If you don't have a roof on it, it will definitely hold. Träguiden has free dimensioning programs, I think there is also an app but I have never tried it. Below is a link to the dimensioning of the pergola, but there are lots of other constructions to choose from.
https://www.byggbeskrivningar.se/dimensionering/pergola/
Click here to reply
