I have a garage with 70mm insulation in the walls. I'm thinking of improving this a bit while I'm replacing the panel.
If I add an extra 70mm, the majority of the finished wall will hang outside the slab. This doesn't feel quite right.
Is there a clever way to build to get an extra 70mm?
If I play it safe and add 45mm extra insulation, "only" half the wall is hanging in the air. Is this OK?
140 mm insulation on a garage!
I have 25 mm sawdust in my house.
Built a workshop with 120mm in the wall and 45mm insulation thickness, really good energy efficiency. There's 500mm loose fill insulation in the ceiling.
Mjo 140mm might be a bit much. But if I'm going to become a ping pong pro and need to keep it warm all winter, I want some economy in that.
At the very least, I'll add 45mm and then almost 60% of the wall is hanging in the air. Feels a bit backwards, but at the same time, we're not talking about gigantic weights/forces.
So, OK?
Yes, it's okay.
Is the eave enough just to protect the walls?
But you shouldn't have it so warm when you train pingis.
It's a very active sport, so you stay warm anyway.
Good luck with pingis! The competition is tough, right?
The roof is enough. Just built a new one.
Table tennis was just an example. In reality, we who build don't have time for anything other than building. :D
Thanks for the input KOW.
Is the inside of the garage covered with plastic? If it's not covered with plastic there but just a windbreaker or nothing at all, you can add insulation on the inside.
Thanks for the tip, but it is laminated. Also, I'd preferably avoid renovating electrical/surface layers inside right now.
I have 190 in the walls and 400 in the ceiling of my garage =)
Oppe said:
I have 190 in the walls and 400 in the ceiling in my garage =)
Maybe a little difference in insulation needs between Västerbotten and VG...
KnockOnWood said:
Perhaps a slight difference in insulation needs between Västerbotten and VG...
Of course, there's a difference—have you ever heard of a ping-pong player from Västerbotten? Probably not, because they have too warm garages there.
But it's just a guess from me:o
cecar33 said:
Of course there's a difference, have you ever heard of a ping pong player from Västerbotten...
Ingemar Stenmark :rolleyes:
Ok I give up, I didn't think table tennis counted.:wow:
  • Like
KnockOnWood
Click here to reply
