Hello!
I have a newly built entrance staircase under which there is a basement room. The stairs will be clad in granite, but first a waterproof membrane needs to be applied in the form of a welded sheet. The sides of the staircase consist of plastered foam.
See image:
Concrete stair structure under construction with a metal brace on the side. Soil and grass are visible in the background.
Next week, the roofer who is installing the waterproofing layer is coming, and he's wondering how it should be finished on the sides/ends of the stairs.
I'm not quite sure how to do it but have come up with the following options:
Option 1: Fold the sheet over the edge down onto the plaster. Advantage: tight and effective. The water that runs off doesn't crawl back under the sheet. Disadvantage: It's quite unsightly with a 10cm fold down on the sides as he suggests... can it be covered somehow?
Option 2: Install a base flashing/drip edge before the waterproofing is applied. Advantage: Water will drip down outside the plaster wall. Disadvantage: Quite unsightly... and how do you handle the vertical parts of the stairs (risers)?
Option 3: Let the sheet protrude 5cm from the staircase and then let the granite protrude just as much. Underneath, perhaps a small trim or silicone bead can be installed so that water running underneath drips down. Advantage: Probably looks quite nice. Disadvantage: Water might run back under the sheet and along the plaster.
Does anyone have tips or opinions on how to achieve this attractively?
I would like the appearance below... but in that case, no waterproofing has been used and the overhang on the stones is very small.
Granite-clad outdoor staircase with sleek, minimal design. Steps show neat craftsmanship without visible water barrier. Seeking advice for water drainage solution.
Click here to reply
