I'm planning to build a shelf above the desk. With lighting, hence the frame. But I need tips on how to make the curve between the short and long side in the best way? The shelf consists of 12mm MDF and 44x15 as edging.
The brown-colored part in the picture is my main concern.
How would you do it?
3 mm masonite that you laminate in a pre-bent shape?
For example, if you cut the right shape out of 2 mdf boards, place a piece of lumber or board between them for height, and use it as a form and brace for a couple of clamps. Glue a few strips of masonite together and clamp them against the form before the glue dries.
Could it work?
