Conditions:
Planning to frame a small ceiling for installing an inner ceiling. 1.6 x 1.1m
Lower by at least 4cm (on the "inside").
Using gypsum
Concrete ceiling and gypsum walls
Questions:
Steel studs along the length CC 30? Skip short sides?
Or build a frame in the wall and attach there?
Which steel studs are meant for ceilings, all?
Anything else? :D
Pour in your best tips! :geek:
Tekniker Tekniker said:
Conditions:
Plan to frame a small ceiling to install a suspended ceiling. 1.6 x 1.1m
Lower at least 4cm (on the "inside").
Use drywall
Concrete ceiling and drywall walls
Questions:
Steel studs lengthwise CC 30? Skip the short sides?
Anything else? :D
Hit me with your best tips! :geek:
45 sk on walls and 25mm secondary profile across the short length. That way you don't have to hang the mess from the concrete ceiling. Or you can put a hanger in the middle with one or 2 hat profiles if you're the nervous type.
I Installation said:
45 sk on walls and 25mm secondary profile on the short length. Then you don't need to hang the mess on the concrete ceiling. Or you can put a suspenders in the middle on one or two hat profiles if you're the nervous type.
I'm not particularly nervous but want to get it right.
You mean it's enough to attach only along all walls? Then try to slap up a sheet in one piece? No risk it will warp?
Just planning to have 2 spotlights and transformers, no other special weight.
Not particularly nervous but want to get it right.
You mean it's enough to attach only along all the walls? Then try to put up a sheet in one piece? No risk of it buckling?
I'm just going to have 2 spotlights and transformers, otherwise no special weight.
or make a joint in the middle and plaster. A bit more work but much easier to work with. If you want to do it really well, use double gips.
So these two?
Seems to just have drywall, so screw into the wall with plugs and screws every 20cm?
Feels like the secondary rule should be very stable considering the folds, and my short distance. So I think I'll skip installing anything in the ceiling. Set these CC 30 so the drywall should be happy.
Steel framing stud "Primärregel Norgips" for drywall installation, dimension 45x3600mm, shown on a white background.
Steel stud for drywall installation, Norgips 25/85 model, shown on a white background, used in building projects for wall support and stability.
So these two?
Seems to only have a plaster wall, so screws into the wall with plugs and screws every 20cm?
Feels like the secondary rule should be very stable considering the aspects, and my short distance. So I think I'll skip installing anything in the ceiling. Setting these at CC 30 should make the plasterboard happy.
[image]
[image]
screws in the plaster are enough. There are probably studs at 45 cc. If it's close to the ceiling, there is a skp there. At least 25mm high.
  • Like
tergo and 1 other
Click here to reply
