6,282 views ·
6k views
How to best close a basement window?
Googled and it doesn't seem to be concrete hollow blocks. (If concrete hollow blocks mean blocks of concrete with cavities in?)B BSOD said:Is it concrete hollow blocks?
Spontaneously, I find it very hard to believe that you would have load-bearing issues if you install a 100 mm hole, but I'm not a structural engineer.
We have roughly the same. I've drilled holes for a chimney, culvert, and drainage through such a wall. A bit of work. Either you use a diamond hole saw with the right diameter. These are quite expensive (perhaps can be rented?) or you drill in a circle with a smaller concrete drill and knock out the contents with a sledgehammer and finish it up at the end so it looks nice.
You can install a slightly smaller window so you have room for a fan beside or above the window if you're going to replace it.
What we have looks like solid concrete mixed with small stones. 1930s house.
That sounds difficult to drill a hole in!
I would probably switch to a slightly smaller window, and fix ventilation next to/above the window... or...
Maybe you can check how much it costs to hire a company to drill a hole in the wall? At work, we sometimes drill through solid concrete walls for various installations. I don't know if we have a good agreement, but it usually costs around 3-4 thousand per hole (around 100-150mm).
Thanks! Yes, those are two good suggestions - either small window + fan or keep large window and drill a hole (with the help of a company). Doesn't sound entirely impossible price-wise. Thanks!B BSOD said:That sounds difficult to drill through!
Then I would probably switch to a slightly smaller window, and fix ventilation next to/above the window... or...
Maybe you can check what it costs to hire a company to drill holes in the wall? At work, we sometimes drill through solid concrete walls for various installations. I don't know if we have good contracts, but it's usually around 3-4 thousand per hole (around 100-150mm).
Member
· 1 030 posts
buy a new insulated triple-glazed window with a built-in slit vent or hole vent. New window and ventilation. Everyone's happy. I would never think of sealing a window in a basement that was also so nice.
Click here to reply
