I have never seen such a panel that is cut in the middle. How is it used and what is the purpose of the cut?
  • Stack of wooden panels with center groove, query about their use and the purpose of the groove.
Design. :D Looks like a slim panel. Modern now.
richardtenggren
It is purely aesthetic, plus it's quicker to install one board compared to two of the same width.
Okay, so you don't need to put battens on then? I guess it's standing panel? Does anyone know what this might cost per linear meter? :)
Sure. You need läkt.
richardtenggren
I think we can assume that TS is referring to lockläckt and not spikläkt, which is probably what @Nyfniken is referring to :)
Lockläkt: no
Spikläkt: yes
  • Like
Nyfniken and 1 other
Thanks for the reply. Thought you'd need a trapdoor.
Can the panel be horizontal?
L Linuswest91 said:
Can you have the panel horizontal?
I don't think that's very suitable!
Both in the tongue and groove and the middle groove, there will be horizontal surfaces where rainwater will stand, eventually causing algae and mold growth and rot.
If you want horizontal paneling, I suggest you choose a facade and skip the middle groove.
@KnockOnWood thanks for the answer.
Last question, does anyone know what the board might cost per linear meter?
Click here to reply
