Hey!
Thinking of casting something similar to this
I've made the mold in plywood, but any tips on how to make it "hollow" to make it lighter? Maybe place some cardboard tubes or similar!?
Does it need reinforcement if the walls are about 10cm?
Then what's best for sealing gaps in the mold?
Made a similar bench. Put in a piece of foam (Styrofoam) of suitable size while filling the concrete. Turned out great.
I didn't reinforce since there's no load to speak of.
Seal gaps with latex caulk.
Thanks, good idea, we'll go with thatmexitegel said:
Now I'm a little unsure about what I used for that one actually
Either regular fine concrete or expanding concrete. With the latter, you are guaranteed a good result as it doesn't need vibrating; you just need to tap the form a bit to achieve an almost completely pore-free casting.
Fine concrete works well too, it just needs more vibrating and is harder to make as pore-free.
Hello again, do you think I need to cover it in plastic and spray with water, etc.? I was thinking of casting at work to avoid making a mess at home and I don't have the possibility to come every day to water it. Will it still be acceptable?mexitegel said:
Now I became a bit unsure about what I actually used for that.
Either regular fine concrete or expanding concrete. With the latter, you get a guaranteed good result as it doesn't need vibing, it's enough to tap a little on the mold to achieve an almost completely pore-free casting.
Fine concrete works well too; it just needs more vibing and is harder to get as pore-free.
Click here to reply
