I have a larger TV that weighs about 50 kg to be mounted on the wall. It is a drywall with wooden studs.
My idea is to put some type of rail behind the TV that is screwed into the studs, and the wall mount is screwed into the rail. However, I am unsure about the material as I want it to be as thin as possible but still durable enough.
Any tips?
Any tips?
Know-It-All
· Västra götaland
· 10 998 posts
If it's not a swiveling mount, then a couple of four Mollys should be perfectly sufficient...
50 kilos should be a large TV, which means space for a wide mount, so it shouldn't be impossible to find two studs... If you do, you're all set!
Yes, it's 85 inchesDan_Johansson said:
Third-party mounts are more like long mounts. Unfortunately, there are two studs relatively close on one side of the TV, and the next stud is outside the TV's frame.
Know-It-All
· Västra götaland
· 10 998 posts
Do you have a picture of the fästet?
Get a plywood board, for example, 12 mm and cut it to the width you need and about 50 cm high. Use carriage bolts from the back and attach the brackets with nuts. Attach the board to the studs with 3 coach screws in each stud. It will easily withstand 50 kg.R Riverground said:Yes, it's 85 inches
The producer's own mount that I prefer to use consists of two separate brackets on each part of the TV, where I can only hit a stud for one part.
Know-It-All
· Västra götaland
· 10 998 posts
Amen.D Dr Jumping Jack said:
Except for lag screws, they are an abomination...
Here is a picture.Dan_Johansson said:
Yes, maybe a plywood attached to two studs and then with molly in the drywall. The mounts then in plywood.
https://www.samsung.com/uk/tv-accessories/no-gap-wall-mount-wmn-r30e-wmn-r30ea-xc/
Don't you have vertical studs? Then you should easily be able to secure four fastenings in the wooden stud in a rectangle. If you use slightly thicker screws like 6mm 75mm long, they will never come loose. Then you can attach the TV to the board. But I would use 15mm plywood.
I have two studs about 40cm apart on the right side, then there is 120 cm to the next one, which is outside the TV.J Johan456 said:
So what I can do is attach a plywood board where one side and the middle are fastened to the studs and the left side is fastened with molly.
That should still create a stronger attachment
Click here to reply
