A Astd_ #1 Member · 12 posts 1 Jul 2024 at 11:21 PM Astd_ Member 12 posts 1 Jul 2024 at 11:21 PM #1 Is it possible to fix this nicely or is it just a matter of getting a new board and redoing it?
Immobil #2 Member · Blekinge · 10 768 posts 1 Jul 2024 at 11:25 PM Immobil Member Blekinge 10,768 posts 1 Jul 2024 at 11:25 PM #2 A Astd_ said: Is it possible to fix this in a neat way, or is it just a matter of getting a new disc and redoing it? Isn't it easier to move the box?
B BSOD #3 Member · Västmanland · 5 211 posts 1 Jul 2024 at 11:29 PM BSOD Member Västmanland 5,211 posts 1 Jul 2024 at 11:29 PM #3 Carve out a little more, fill with something like putty. Plaster would have been ideal if you had it available at home, I would probably say.
AXS #4 Member · Sthlm · 2 705 posts 2 Jul 2024 at 12:00 AM AXS Member Sthlm 2,705 posts 2 Jul 2024 at 12:00 AM #4 Or cut out a smaller piece, put a new piece there and drill a new hole in it. 30x30cm should be enough. You can indulge with some plyfa behind the joint so it holds well.
