If the pillars go straight through the deck with about 1 meter protruding, it will work fine. If they are new posts for the railing, it will be a bit trickier to make it steady and not wobble. See how you anchor the posts. Maybe cut up at the pillars on the upper side and attach about half a meter down. What material are the pillars made of?
Yes, the posts are very stable. They are cast in place and support the roof.J jonaserik said:If those pillars go straight through the deck with an extension of about 1 meter, it should be fine. If they are new posts for the railing, it will be a bit trickier to make it stable and not wobble. See how you anchor the posts. Maybe cut up by the pillars on the upper side and secure about half a meter down. What material are the pillars made of?
Do you mean that it should be fine to install a wooden fence without extra pillars?
Click here to reply
