Planning to install plasterboard on the ceiling and considering choosing Norgips Plan with recessed edges on all sides to increase the chances of a smooth ceiling.
Two questions:
1. Is it worth the extra cost, i.e., is it easier to get a good result?
2. Is there any other product apart from Norgips Plan that has recesses on all sides? The local store just ran out of theirs.
P
Yes, it's definitely worth the cost even if you have higher walls where a single board isn't enough in height, it's good to use these boards.
I believe most manufacturers have these boards; I think Gyproc calls them planum..
Any reasonable building materials store should be able to order the desired amount..
  • Like
Rickard.
100% worth it.
  • Like
Rickard.
Knauf calls its surfaceboard
4ak edge
Sounds like you agree on the usefulness. I'll have to check what's available, as usual, right on time.
There's a significant price difference between different brands and compared to regular ones (I assume the manufacturing process is more complicated).
Click here to reply
