16,238 views ·
16k views
Distance wall - drain under sink.
Time to frame the interior walls in the construction...
I have a concrete slab with a cast-in 75mm drain for the sink.
What distance (from the finished wall) to the drainage pipe should/usually is there?
I seem to recall the plumber mentioned something about 8cm, but I'm a bit unsure?
Hobby electrician
· E
· 15 575 posts
The pipes from the sink are usually forgiving regarding where the drain comes up, but you should be able to lift the cabinet into place, and the pipe shouldn't come out too far and be in the way, so 8 cm feels just about right.
Click here to reply
