1,089 views ·
1k views
Cut/saw drywall that is up to move door.
I am going to move a door, create an opening in another wall, and I assumed it was particle board on the wall which I would cut with a circular saw. It turns out now that there are plasterboards on the walls, and it doesn't feel like a circular saw is the best tool for this job. Jigsaw, a simple handheld drywall saw? What is the best solution? It's about 24 meters to cut. Thanks
A circular saw works, but it produces a lot of dust if you don't have good dust collection. However, 24 meters is quite a long distance to cut with both a handsaw and a multicutter...
If dust isn't a problem, I would use a circular saw, put on a respirator, and just go for it.
Click here to reply
