6,345 views ·
6k views
Cut many sheets at once?
Hello!
I need to cut a bunch of tp20 sheets that are about 20cm too long. Is there a good way to cut many sheets at once? I was thinking if I clamp them with a board on top and bottom and cut along the board with a jigsaw with a metal blade?
I assume you can only nibble one sheet at a time? I'm not too concerned about the cut surface being perfect, as the cut end won't be visible anyway. I just don't want to damage the sheet (or the tools).
Otherwise, the plan is to nibble them individually, but that takes some time, and they're cumbersome to move on my own when they're 4m long.
Suggestions?
Suggestions?
It works to do as you're thinking. It might be challenging to get the jigsaw to go straight, so a board is a good idea. In general, it's a bit tricky to cut corrugated metal with a jigsaw.M Markus P said:
Yes, I figured that a jigsaw might not be the best option, but the blades are so much cheaper than buying a metal blade for the circular saw...
The thing about the angle grinder sounded interesting. You're not supposed to use it to cut rust-protected sheet metal, but if they are close together and you cover the top one, maybe it won't be a problem? It would certainly be the easiest way to cut through that way, and the cheapest =). Anyone else have anything to add about this option? As mentioned, it seems "obvious" otherwise =D.
The stickisen works if you tighten two boards with a gap between both above and below, the saw blade runs in the gap and the whole saw has a flat surface to run over... otherwise, the angle grinder is the easiest except for all the spark spraying.
Assuming it's not too thick sheet metal, a 0.8mm disc is great if you're going to cut painted sheet metal. Not at all the same heat development, so the paint usually holds up surprisingly well.S sixten88 said:
You might have missed the part where it was discussed to cover the top sheet.S sixten88 said:
There is often more heat development with a reciprocating saw, for example.
Regardless, it becomes too hot so the paint comes off closest to the cut. Using a reciprocating saw or a tiger saw aggressively is also not good. My advice is for TS to proceed very carefully with a plunge saw with a blade for metal.
If it gets so hot that sparks fly from the reciprocating saw, then you're probably doing something wrong.C C.Lundin said:
I also advise against cutting with an angle grinder/cutting disc!
